Bought an electronic SVDA dizzy from SimonBBC online. Having watched fisher buggies video to remind me how to set the timing and valves. I have done the following.
Placed engine at TDC. Checked cheap dizzy in engine and rotar arm at 5 o'clock. Removed cheap dizzy placed in new Bosch electronic SVDA. Bosch unit fitted and rotar arm at 2 o'clock.
I am going to check my valves and set everything back together with number one at 2 o'clock then 4 3 2 etc. The dizzy is correctly engaged.
The engine is on the bench at moment so hoping this will be ok. I have heard that the units can be put together wrongly in the factory. Also bought this as Bosch but no markings on the unit itself.
Reading on tinterweb as long as the leads are in the right order there should be no issues
