Is there a smaller shock out there to purchase ? I think the bugpack and kyb gr2's compress to 245mm so if you go softer in the same size they will bottom out.
I've got the gr2's but in the 265mm and they bottom out with two up front on uneven roads and I'm 510mm floor to arch ,not as low as you guys.
If I fitted the 245mm gr2's this would work but then if I lowered it 20mm I'd be in the same predicament :| The gr2's are a nice ride though
