brake fluid proof hose
67panel
Jul 30, 2009
2,727
156
malven
I need about 4ins of 12mm id brake fluid proof hose, wondered if anyone had a bit left over from replacing there feed pipe?
I'll check presume you are after EPDM or whatever its called, I think the stuff we usually use is 13mm ID but i'll check.
From the reservoir to the master cylinder (no pressure) I used flexible plastic hose that they use for like ice machines and such. I have been watching it for deterioration and leaks, its been a year and its not looking bad at all. The supposed stock hose just would not work/cooperate
