Hilly_70
Hi Guys
Not been here for a little while..busy with bus and knackered laptop .. but I really need your help!
Right .. just putting bus back on road after 5 years..
|About 2 years ago replaced most brake pipes, cylinders, shoes ( all drum ) flexis etc ..
Last week used an easybleed kit and bleed brakes .. got pedal pressure and test drove ..
Pulled to right so stripped LHS front and although newish, piston stuck in .. removed all front cylinders and free'd up and cleaned ..
re bled using same method ( Easybleed pressure via resevoir )
Bled from rear to front till no bubbles .. prob pushed around half a litre through system ..
No pedal pressure ..
Rebled using standard method with mrs .. no bubbles ..no leaks ..
stripped drum and pedal does move pads but cant get pressure to pedal..
Am I just airlocked or is the master cylinder farked?
I know you guys can sort me out ..
Hilly
PS .. I'll put a piccy up in gallery of my bus now ..
Hilly
