I've been in touch with Karl at Autocraft, and he says that the sill section they sell for the Split crewcab, also fits a Bay, I'll be ordering a pair on Monday for mine, so will let you knowyoung_dubya said:Did you buy a long split sill panel and mod it for the rear section with the flange or did you by it pre flanged?
Mine are standard bay sills from Schofields, I then cut & modded it, still got the other side to do,& looking forward to you boys posted some updates too !young_dubya said:Did you buy a long split sill panel and mod it for the rear section with the flange or did you by it pre flanged?
I've got a replacement floor from schofields (the same as camper). I'm going to first finish a few bits then do the sills on the other side, before having the exposed lower & raised cargo floor metal work blasted, then etch primed & probably painted before welding the floor panels in.moler said:Sorry if you've covered this already, but what are you doing about the inner cargo floor?
What are your plans for the door edge? do Schofields make this piece? a crewcabs door edge is a bit different to a camperBO JANGLES said:I've got a replacement floor from schofields (the same as camper). I'm going to first finish a few bits then do the sills on the other side, before having the exposed lower & raised cargo floor metal work blasted, then etch primed & probably painted before welding the floor panels in.moler said:Sorry if you've covered this already, but what are you doing about the inner cargo floor?
Do you mean the sill under the rear door or the bottom of the door ?moler said:What are your plans for the door edge? do Schofields make this piece? a crewcabs door edge is a bit different to a camperBO JANGLES said:I've got a replacement floor from schofields (the same as camper). I'm going to first finish a few bits then do the sills on the other side, before having the exposed lower & raised cargo floor metal work blasted, then etch primed & probably painted before welding the floor panels in.moler said:Sorry if you've covered this already, but what are you doing about the inner cargo floor?
BO JANGLES said:8) Can you let me know what you find & thanks for the info.
