lard
Having carb woes at the moment (eratic idle, stutter and fuel leak) - it's a bocar 34 pict 3 and looks a few years old, but is leaking round the throttle bushes, took it apart last night and the bushes are already metal rather than plastic (have brass ones to replace), quite a bit of play in the shaft, as it was couldn't get the brass screws out of the butterfly valve :| - I thinking the brass bushes I have are for repairing the plastic bushes on solex rather than the alu ones on my bocar?
anyhoo - when running it this morning noticed loads of condensation forming on the inlet manifold under the carb and on the body of the carb itself, my pre-heat isn't connected (need a stock filter which is next on the list!) - is this is what as known as icing? and is it normal for the carb to be so cold to the touch on idle?
Just curious if it's a sign of something else, light lean/rich e.t.c.
oh, and I've contacted Keifer on thesamba for a refurb'd solex carb, as mine looks so worn after such a short time thought I'd draw a line under it and get an OG one!
