So, got the van back from the MOT, and all was working sweet as a nut
However, one of the ongoing issue i have had is to get a consistant idle!
thought i had it dialed, however when getting home today the van just wouldnt idle, so once AGAIN, i reset everything back to factory (book) settings. (2 1/4 turns)
Lots of fiddling later and its only half idling, the carb is question is a Bocar 34pict3......My initial thought was to keep fiddling and clean the buggar out, however im slowly thinking of going down the route of buying a Solex carb.
Any top tips out there, have done a bit research and just seem to be turning up something about the hole in the butterfly valve.
Its just getting really annoying not being able to pull up at a junction and knowing if the engine is going to die!
I believe the timing is ok, as all revving up fine and not too hot. plus i have pertronics.
cheers,
Luke
cheers,
Luke
