lard
gee said:sounds to me like youve got an air leak it doesnt always show when you go up the rev range i would get a can of wd 40 [ive always used easy start,but not everyone is comfortable with spraying it around the engine bay] and spray around the usual suspects inlet manifold gaskets, rubber manifold connection pipes ,carb manifold gasket,if the revs go up or it starts spluttering/dying then bingo youve found it this is best done on tickover if youve swapped carbs for one you knows is working then it cant really be jet sizes... :mrgreen:
Just to note the test carb came jetted as is from JK - was working on mine (but then my bus might have a tolerance for incorrectly setup parts
