Came back from hols the other day and took the van out for a spin. Most the journey was find until the generator light came on and the battery stopped charging. This seemed to happen when I switched the indicators on, although I had used them previously on the journey no problem. The voltage of the battery dropped to around 7 volts (on my dash volt meter) and the indictors wouldn't work at all.
Anyway I was at home and I left the van for a couple of hours. I went back out to look at it and it started and charged no problem....for about 5 miles...then it happened all over again.
I have a theory that its all to do with the ice and snow. My van lives outside and gets pretty damp at this time of year. Could it be that as it defrosts on a journey the ice is turning to water and wetting a circuit causing this problem? I don't understand why it stops the van charging though and why it works sometimes and not others. For example when I started it up this morning it was fine until I turned the indicator on...then back to low volts and no charging. If it was a short you'd expect it to be permanent I guess?
Anyway can anyone offer me advice how to resolve this one please? Cheers
