surfbus
@ joaonar
Tried google?
Found it with google overhere: http://www.ampcolubes.com/
Tried google?
Dry fuels can harm your engine!
If you use unleaded gas, ethanol, propane, CNG, or Low Sulfur Diesel, your engine needs the original Ampco top cylinder lubricator!
The Ampco top cylinder lubricator provides critical valve to seat lubrication, which is now absent from gasoline, and prevents sticking valves and detonation caused by carbon and combustion deposits.
Compressed gas fuels contain NO LUBRICATING PROPERTIES! They burn clean and may be “environmentally friendly”, but burn hot, are corrosive, and can cause very premature valve failure. The only way to introduce lubricity to a compressed gas fuel system is with the Ampco top cylinder lubricator. Sulfur functioned as a valve seat lubricant in diesel fuel. Low and ultra-low sulfur fuels can cause valve recession problems in older diesel engines.
