Coil test.
gas1man
Apr 22, 2012
2,283
318
Dorset
Year of Your Van(s)
1971
Van Type
Dormobile
4000 mile old coil ,Beru blue and it died?
Have bought replacement. Anybody able to explain how to test if it is cooked, will
need to be in basic language, I do have a multimeter to test with.
Any help appreciated peeps.
Thank you
J & P
:D :D :D
To check the coil, remove the ht lead from the coil to the centre of the distributor cap, switch on the ignition, hold the end of the lead with insulated pliers about 1/2 inch from the engine block and turn the engine over. There should be a spark, if not, then check the voltage at the +ve terminal (terminal 15), it should be at least 9V.
If this voltage is higher, check the voltage to earth at terminal 1 (coil connection). This should be 0V when the points are closed, and a voltage will be present when the points are open. If there is no reading when the points are open, the coil is open circuit and must be replaced.
Remove all of the wires from the coil terminals (remembering where they go) and using an ohmmeter attach the meter leads to terminal 1 and terminal 15 on the coil. You should get a reading of between 3 and 4.5 ohms, which is the coil resistance. A faulty coil will show a higher reading.
Next connect a lead from the meter to the centre ht connection and the other lead to either one of terminals 1 or 15. The reading should be around 9,500-10,000 ohms. It may be less but shouldn't be anywhere near 11,000 ohms. If you have no reading at all, the coil is faulty.
Thank you sir! To kind.
Tested and totally cooked , no readings at all no matter which way.
J & P
:D :D :D
