Most of the work over xmas was preparation work ready to start the rebuild.
Dash
The other-side of the welded dash was cleaned up and given a layer of POR15, ready to go in when the loom's done.
Rear Hatch
POR15 paint down ready to give that extra protection against standing water. It looks tidy as the rubber seal sits on top of it.
New stainless fixings 8)
New seal nicely in.
Fuel Filler Cap
Took this section apart to clean up properly and put protection paint down.
I also sourced a new filler pipe and clips from Demon Tweeks as the one on VW Heritage is
wrong!
Deck Lid
Did some straightening out of the metal lip ready to accept the rubber seal, then put down protection paint again.
Headlining
Started pealing back the old headlining so I can put some protection paint around the window seal areas. Plus I need this down anyway ready to install a new one. I might POR15 the whole inside roof depending on condition. Then build up sound proofing / headlining
Front Screen and Clip
Following on from the above. I also put as much P15 as I could over the inside-lower clip area. I imagine condensation will like to pool there.
Front screen surround done.
Rear Bumper Irons and Spot Light Brackets
Cleaned up some South African rear bumper irons and coated in a couple of layers of P15 along with some spot-light brackets.
Side Cover
O/S side cover, straightened up the locating metal lip and again applied protection paint down on inside of covers and around shell location, new fixings and welded captive nuts.
