Passion 4
Dell UltraSharp 2007WFP 20.1-inch Widescreen Flat Panel LCD Monitor – Collection from the seaside in Hastings, £30
Great condition 20.1" monitor complete with mains power lead, USB power lead and DVi connection lead. Good colour accuracy for graphic design, photography or video work and is in the more desirable matt anti-glare finish. It includes two very useful additional USB ports on the side for additional connectivity. Native Resolution is 1680 x 1050 at 60 Hz with a contrast ratio of 800:1
The Dell UltraSharp 2007WFP 20.1-inch Widescreen Flat Panel LCD Monitor is a wide aspect desktop display that redefines the performance of LCD displays with a stylish Dell industrial design, and advanced functionality. With this monitor, you can watch DVDs in a natural format, run multiple applications simultaneously and improve productivity with less scrolling and toggling.
The 2007WFP provides an excellent option for video editing and 3D imaging as both source and destination video can be viewed in a single window. It also supports advanced features such as PIP (picture in picture) and PBP (picture by picture) and can be activated with a touch of a button right in the front of the display. With the included height adjustment stand, every user can adjust the display to their exact comfort level and help reduce eye and neck strain.
Display Type LCD monitor / TFT active matrix
Native Resolution 1680 x 1050 at 60 Hz
Contrast Ratio 800:1
Dimensions (WxDxH) 18.6 in x 7 in x 13.1 in
Horizontal Viewing Angle +89 / -89
Vertical Viewing Angle +89 / -89
Viewable Size 20.1"
Pixel Pitch 0.258 mm
Brightness 300 cd/m²
Screen Coating Anti-glare, hard coating
Horizontal Refresh Rate 81 kHz
Vertical Refresh Rate 76 Hz
ManufacturerDell, Inc.
POWER DEVICE
Nominal Voltage AC 120/230 V
Frequency Required 50/60 Hz
Power Consumption Operational 75 Watt
MISCELLANEOUS
Colour black
Flat Panel Mount Interface 100 x 100 mm
DISPLAY
Image Brightness 300 cd/m2
Image Contrast Ratio 800:1
Type LCD monitor
POWER
Power Consumption Stand by / Sleep 2 Watt
Power Supply internal
CHASSIS
Built-in Devices USB hub
INTERFACE PROVIDED
Qty 1, 4
Connector Type 15 pin HD D-Sub (HD-15), 24+1 pin digital DVI, 4 pin USB Type A, 4 pin mini-DIN, RCA
VIDEO
Video Output none
ENVIRONMENTAL STANDARDS
EPEAT Compliant EPEAT Silver
ENERGY STAR Certified Yes
VIDEO INPUT
Digital Video Standard Digital Visual Interface (DVI)
Analog Video Signal S-Video, composite video
MECHANICAL
Display Position Adjustments Height, swivel, tilt
ENVIRONMENTAL PARAMETERS
Min Operating Temperature 41 °F
Max Operating Temperature 95 °F
Humidity Range Operating 10 - 80%
DIMENSIONS & WEIGHT
Width 18.6 in
Depth 7 in
Height 13.1 in
Weight 14.33 lbs
Viewable Size 20.1"
POWER DEVICE
MISCELLANEOUS
Colour black
DISPLAY
Type LCD monitor
POWER
CHASSIS
INTERFACE PROVIDED
Qty 1, 4
VIDEO
Video Output none
VIDEO INPUT
MECHANICAL
DIMENSIONS & WEIGHT
Width 18.6 in
Depth 7 in
Height 13.1 in
Weight 14.33 lbs
