It does pain me to write this 1 so here goes
Lhd arizona Earlybay deluxe tin top original paint its solid its loaded with goodies
: 2054cc all new engine - that is new case new crank ,pistons bearings heads are 044 magnum , 94 barrels pistons so its a high speck engine all top make/quality stuff no exspence spared the list goes on its done about 1500miles tops
:At code Fresh Build Zero Miles 1600 IRS (1500miles)
AT Code
Super diff
Heavy duty Aluminium side plate
ratios
longer 1.21 3rd
longer 0.82 4th
both welded hubs and converted to run with
super beetle mainshaft
4 spider super diff
:csp shifter
Burg balanced fan
Twin 40s dells
:t2d narrowed beam kit -dropped spindles adjustable beam
:westy interior-wardrobe,buddyseat, r&r bed recovered in leather,table and overhead locker
:adjustable springplates
:dormobile cook under passenger front seat
:buttybits part for easier pedal
:new discs, servo
: Protech alloy billet - custom built front shocks
:alot of window rubbers rear hatch,slide door been done
:vintage speed exhaust
:external remote oil cooler
List goes on......................
this van has been lovingly been restored shame to let it go but go it must, its worth every penny if you count engine,running gear,gear box ect ect
DEPOSIT TAKEN blackpool dave tel 07973876221
the van has been gone through and is a solid van
AT Code
Super diff
ratios
longer 1.21 3rd
longer 0.82 4th
4 spider super diff
:csp shifter
Burg balanced fan
Twin 40s dells
:new discs, servo
