Hello guys.
My engine and bus are almost there.
Found TDC using a long glowplug with machining marks on down the plug hole, checked so many times and it incidentially lines up with the marks on the pulley. It's a pulley off another engine.
This engine (industrial 126) had a sticker on the fanshroud for 7.5 BTDC static timing set up which is good.
When the engine is set to TDC the slot in the distributor driveshaft points at a slight angle towards the crank pulley rather than straight along the front of the case. Is this correct for engines that need to be timed at 7.5BTDC?
OR do I need to remove it and line it up with the front of the case?
The engine was built by VW in Germany in 1973 and has done 12hrs so far, that's why I'm hesitant to changing anything...
A quick reply would be really helpful as I'd like to complete engine assembly and installation today.
Thank you as always for your time and efforts.
Andy
Andy
