danielgomez
Active member
Could I order one of these?
Dan.
Dan.
Nice one , atleast i know it works from a buying point of view , will post out in the morning , thanks again ...SpenceBoosDad said:Ordered thru your new website!
Nice one
Spence
butty said:Nice one , atleast i know it works from a buying point of view , will post out in the morning , thanks again ...SpenceBoosDad said:Ordered thru your new website!
Nice one
Spence
To anyone who fancies visiting the site its http://www.buttysvwparts.com" onclick="window.open(this.href);return false; not everything on there at the mo , kind of finding my way with it all , slowly ....
Nice one , no big issues fitting it ? I have done several but not had many other people get back to me on there experiences of fitting . Cheers For posting ....lard said:Got mine and fitted yesterday nice smooth throttle action!
butty said:Nice one , no big issues fitting it ? I have done several but not had many other people get back to me on there experiences of fitting . Cheers For posting ....lard said:Got mine and fitted yesterday nice smooth throttle action!
Nice one Spence glad you fitted it ok ..SpenceBoosDad said:Fitted mine today!
Totally easy-peasy including fitting the return spring.
Didn't need to remove the top ball-joint either. What I did was lube up the inside of the rubber gaitor with copper slip, just took off the top ball-joint clip and the top ball-joint went through no problem - put the clip back on and cool.
I've just got a slight issue totally unrelated to the kit though - my throttle cable had jammed - I'm guessing this could have been what helped my original linkage fail.....
Had to give it a hefty pull with some pliers to release it.
Think I need to establish where the problem is - may need a new cable.
The pipe at back of the fan housing seemed a bit loose - is this normal????
Spence
Cheers . I would also try lubricating the cable tubes aswell . Sounds like youve been having fun . When it was working was the cable hard to pull ? As in if you took cable off at pedal end and pulled it , did it move back and forward easily ?Merlydog said:Just ordered one butts...
This was actually the final straw when I almost sold my bus lol.. It's a long story but I've been through three linkage levers from a major aftermarket parts supplier for Vw's. The first two snapped before I even got off the drive, the third one was welded by the company, a fantastic gesture I thought and surely that will do the trick?! It lasted around 2-300 miles then snapped again 1 mile away from my new house on moving in day!! I wasn't a happy bunny as you can appreciate having had a very stressful day.
Just thought I'd share as my personal experience is the after market parts for the linkage kit is tosh, I've only heard good stuff about these both here and on SSVC so I'm looking forward to getting it fitted and forgetting about it.
Thanks Butty.
Im pretty sure it will fit . But as with everything I sell if it doesn't work for you bung it back for a full refund .67westy said:I'm really interested in one of these. Can I just check that it will definitely fit an early 68MY? I bought a few bits a while back to replace worn parts but I seem to remember that the linkage I had was pretty different to what was on the VWHeritage site diagrams so the parts didn't fit :roll:
I guess I need to crawl under the bus at some point and have a look![]()
