Engine SOLD
TES (The Engine Shop) Green spec, recon engine .. only covered 7k miles.
Had been sitting in the back of a rusty bay for a while, so the top end was stripped down to replace the push rod tube rubbers along with other seals & gaskets.
Has a new Hella dynamo, newish carb & 200mm clutch. also after market oil filler neck, alloy crank pulley & brand new J pipes.
Full service : spark plugs, ignition leads, points, condenser, oil, fuel pipes .. will have new dissy cap & rotor arm.
May look tatty, that's just flaky paint .. all the tin is good and solid no holes or tin worm.
Runs perfectly .. obviously no end float or oil leaks etc.
Has bus exhaust & breast plate, good threads for rear mounting bar.
Front N/S wheel arch, OG cut in good solid condition. Has been cut short, bout 10mm from the tab that's welded to the A pillar £130
CE code Gear box, only covered 53k .. in gwo with no issues £200
Louvered window in vgwo & condition, £70
Paul on 07975 973134
Kettering, Northants.
