I have a 2110cc engine. I've noticed it has a knocking / ticking type noise when the engine is running.
The noise is steady on idle and rises in speed as the rpm increases, the noise is coming from the drivers side of the engine.
Any ideas what could be causing the noise, valve gaps? Bent push rod? Timing out? Carbs set up wrong.
The engine has always had that noise since I got it second hand as a turnkey engine a few years ago I've not driven it much and hope to use it a lot more next year so would like to know if its anything I need to worry about.
Any advice is appreciated
