raveboy
- Joined
- Nov 16, 2010
- Messages
- 154
- Reaction score
- 6
- Location
- Andover, Hampshire
- Year of Your Van(s)
- 1968
- Van Type
- Ex Microbus
Ok dubchaps, arty0021: arty0053:
Just put the rebuilt engine back into Arthur and am a little confused as to the wiring. I bought a new coil (See below)
But it only has + & - terminals on it - Not 1 & 15. So what wire go's where - I have the green wire from the dist, the black
wire from the main loom and the red wire from fuel cut off solinoid and choke. Also what are peoples opinions on this cheap coil
- Is it crap and should I have gone for a more expensive one.
Another thing I noticed as well is that the heavy fat + battery wire (Comes straight from battery) is connected directly to the
starter solenoid with no apparent connection to the generator. Would I be right in saying that i should have a fairly heavy
connection from the B+ terminal on the regulator going direct to the + on the battery as well ?
Cheers in advance for you help and views peeps
Rave arty0046:
Rave arty0046:
