The 0.3 side float is about normal on the con rod. You need a fair bit of clearance to make it work.
There won't be 1mm at the little end as the barrel holds the piston in place & the gudgeon pin goes through the little end bush. They are tied together so you won't get any more than 0.3 at either end.
In reality the piston & rod find there natural resting place & sit there quite happily.
If your bottom end is sick, you would here it knock when it is running. I doubt if there is too much wrong...
