Hi guys. Me again. Same old issue...
My issue is the engine (as always!). As I have posted before when driving the van will seem sluggish and now at any speed loose power, judder and sometimes cut out, sometimes I can pull over and the engine will idle and I can continue. However tonight it cut out and was 40 minutes before it would start again. When I tried to start it it turned over but would not kick in. With the accelerator down I wasn't getting any revs.
After waiting I then got intermittent and erratic revs. I managed to nurse the van home but it was seeming to struggle pulling.
After advice these are the things I've tried:
- unscrewing the fuel cap to check for a vacuum (there wasn't).
- I've changed the internal stand pipe and gauze, inline filter and fuel lines.
The issue is it can be totally fine start perfectly and then a mile down the road it happens. All I can't think is:
- the engine getting too hot, even though it can be sluggish and stall from cold (then as it cools will start again..?).
- the coil is shot / over heating.
- there is an issue with the leads, plugs or dizzy?
- there is still a fuel issue somewhere?
It's so tricky I think because it's an intermittent issue. We are supposed to be heading to Cornwall next week. At the moment we have no chance.
Thanks as always,
Alex
Thanks as always,
Alex
