jonnyvolks73
Hi all ,
Just been trying to remove the fuel pump to change the gaskets before i refit the carb and i cant get the plastic flange off the block , just wanted to check if there was a knack at doing this as i dont really want to force it to much because it seems brittle any ideas ?
Also does anyone know the type/size of the nuts that hold the fuel pump/inlet manifolds on ?
And finally does any one know what size socket is needed for the fan bolt (only if you know of the top of your head as i could measure it tommorow ) and the best way to remove it when the fan housing is removed ?
sorry does anyone know where i can get the gasket between the pump and flange also , seems that everyone only does the gasket between the flange and case ..sorry guys lots of questions i know ..
cheers
john
cheers
john
