Shorty
OK, so, today was supposed to end with me sharing the good news that I'd got my engine running for the first time...
It isn't :roll:
I started with confirming I had oil pressure without the coil connected. I do.
I initially diagnosed that I had put the fuel pipes to/from the pump round the wrong way. Once correct I checked for fuel in both after cranking the engine. All good.
Next I suspected the electronic ignition / older OG Bosch 009 dizzy, so I swapped that out for the dizzy supplied with the engine.. A new but repro unit running points. This action didn't change anything, so will probably revert once engine is running.
So, having confirmed oil pressure, fuel pump working and eliminated a potentially tired dizzy, I then moved on to the spark.
I grabbed an innocent passing neighbour and got the to hold the timing gun while I cranked it over. My theory at least is that should the timing gun flash, then the spark plugs must be sparking... We got a flash.
I then removed the air filters and poured a thimble of petrol into each.. this helped a little...
However, it seemed that the valves were open on the ignition stroke - instead of exhaust (perhaps_ as I suddenly had lots of popping coming from the exhaust...
hmmmn..
So, swapped my HT cables over 1 for 3, 4 for 2, effectively turning my dizzy through 180 degrees.
I tried it another couple of times, but by now my battery had had enough for today, and frankly, so had I!!
Battery on charge now.
Anyone got any ideas what to do next?
I can't help but suspect the carbs are starving the engine of petrol... I initially thought it could be the coil, but as we have confirmed a spark is present, then I have (rightly?) eliminated that..
It isn't :roll:
hmmmn..
