Fitting JK oil temp gauge kit
thejinx
Mar 30, 2011
1,559
73
swansea
I am going to buy JK’s oil temp gauge kit. The dipstick one as it seems to have the better write up. My question is. I have belly pans fitted so how best to run the cables. Cheers
Hi ,
When I got Boris I removed the peddle pan first then bought some of that fairly hard
plastic tubing that they run wires in behind computers etc. Pushed it all the way through with some patience
and then pulled it tight at each end of the belly pan. Ran a piece of cable through as a pull through first and
another piece subsequently every time for the next addition. I used a piece of 20mm round tube as I knew I
could then add if needed. Ran it from front to back. Protects all from the elements and looks good.
Hope this helps.
J & P
:D :D :D
