- Joined
- Sep 24, 2009
- Messages
- 1,556
- Reaction score
- 65
- Location
- Warwickshire
- Year of Your Van(s)
- 1970
- Van Type
- Microbus
Hi All
Bought this 8 years ago, stripped it down 4 years ago (all bits bagged and labelled) and now got to finally admit i'm never going to get round to building it
Its a 1964 Chrome ring Li125, engine and frame number only 400 out. I have bought a huge number (80-90%) new parts for the rebuild costing around £1500. Basically needs all the frame bits powder coating £200-300, and its ready to build. Looking for offers around £1750.
Full parts list:
1/18 dellorto - inlet manifold (x2)
1/18 dellorto carb (x2)
12v bulb set
185 Head &Barrel kit
22mm jetex - inlet manifold
22mm jetex carb
air box clip - stainless
air filter - steelbirg x2
alloy frame ties
antivibration washers - floor
body rubbers set - grey casa
brake adjuster - front
brake adjuster - rear
brake pedal bracket - rear
brake pedal rubber - Casa grey
brake pedal spring - rear
brake shoes - front - EBC
brake shoes - rear - Ferodo
brake switch & cover
brake/clutch lever anit rattle pin
brake/clutch lever pin
brake/clutch trunion set
cable adjusters
cable cover - candy
cable guides - headset
cable nipples
cable set - nylon - grey
carb air hose
CDI unit - Ducati
Stainless Steel Restoration Kit - Nuts/Bolts/Screws
chian guide - upper
chrome ring - new
circlip kit
clutch kit, plates/springs - surflex
electronic ignition mounting bracket
engine bump stop rubber
engine casing studs/nuts
engine foundation bolt
engine gasket set - kace
engine mounts - GP chromed
oil seal - engine - gufero
exhaust orange AF clubman
floorboard rubbers (front/rear) - casa grey
flywheel inc stater plate
fork bolts/bushes
fork embelishers - stainless
fork link caps
fork springs
frame badge holder
front spindle nuts
fuel tap - fast flow kace
headlight peak
headset bearing - bottom/top
headset c nuts, cups, bearings etc
headset grips - chrome sundance
headset locking ring
horn
horn bracket - stainless
horncast innocenti badge
HT lead/spark plug
hub nut - rear
ignition switch - Kace
inner tube - Michelin Airstop (x3)
kick start bump stop
kick start rubber - Casa grey
legsheild badge lambretta
legsheild badge li125 x2
light/horn switch
mudflap red/white check
mudguard - front (GP)
mudguard - front (SX)
mudguard embelisher - front stainless
number plate surround - stainless
oil seal - hub - front
oil seal - hub - rear - gufero
oil seal - kick start - gufero
oil seal - mag housing - gufero
oil seal - mag drive side - gufero
oil seal - speedo drive - gufero
panel handle (x2) - stainless
panel spring set - stainless
petrol tank rubbers
petrol tank straps
petrol tank trunions
rear badge - casa
rear light gasket
rear light lens/reflector - Aprillia Casa
rear light screw - external
regulator
seat - oxblood red complete
shock absorber - rear - escort
side panel badges x2
side panel buffers
speedo
stand - stainless steel
stand feet - casa grey
stand hooks - stainless
stand splash plate
stand spring
tax disc holder - halcyon stainless
tool box lock - racer
tool box trunions
tyre - Michelin S83 (x3)
wheel rims (x3)
whitewalls - 4 Atlas
wiring loom
cheers
Karl
Full parts list:
12v bulb set
22mm jetex carb
alloy frame ties
cable adjusters
cable cover - candy
cable nipples
carb air hose
CDI unit - Ducati
chian guide - upper
chrome ring - new
circlip kit
fork bolts/bushes
fork link caps
fork springs
frame badge holder
front spindle nuts
headlight peak
horn
HT lead/spark plug
hub nut - rear
light/horn switch
petrol tank rubbers
petrol tank straps
rear badge - casa
rear light gasket
regulator
side panel buffers
speedo
stand splash plate
stand spring
tool box trunions
wheel rims (x3)
wiring loom
cheers
Karl
