Bazzaworld
- Joined
- Dec 5, 2013
- Messages
- 335
- Reaction score
- 0
I know this has been gone over before many times but I'm still confused so here goes again, my bus had little or no front dampening we would feel every pot hole pump etc our fillings would nearly fall every time we went for a drive, the bus had somewhere in its life been fitted with an ajustable beam to lower it slightly but nothing else. I fitted some new standard rear shocks and some adjustable Gaz coilovers, I set these up as follows, bottom spring ring 6cm up from weld and 6 clicks on the damper knob I went for a test drive bus was better but still banging and crashing over holes, so I wound the spring up to 10cm from weld and added 4 more clicks, now it drives superbly the only thing now is the bus is a bit bouncy is this normal or is there some adjustment I should make - I hope all of the above makes sense
