Skidsurf
Hi Just trying to solve the good old fuel gauge issue were all plagued with. (68 bay)
Already replaced the fuel sender, the gauge goes right to full on key turn now, so pulled the dash dials pod out to look at the earth.
Pulled off the earth wire (A) and the dial drops to empty so dial must be ok?
The connector next to it (B) was wobbly though and suddenly touched the casing and blew the fuse!
So I pulled this wire out to take a look and what ever was connected on the inside fell off inside the dials housing!
So is this a simple case of removing the bolts to access inside the housing or will I be opening up Pandora's box here?
Any tips?
Mike
Any tips?
Mike
