robjarman
hi - what's the best way to wire in a fuel shut off valve - through the 15 terminal at the coil? so that when ignition switch is on the fuel valve opens and v.v. - does this mean routing the feed wire to the coil through the fuel shut off valve so they are in series?
the cut off valve has an earth terminal - do I need to ground the valve?
cheers
Rob
cheers
Rob
