Fuse box mounting???
dasteel
Mar 13, 2009
170
Nr Haverhill, Suffolk
Hi
Has anyone got any pictures of a 71 fuse box showing how it should be mounted and with what (mounting plates etc..)? When i got my bus it was just hanging behind the dash and i'm not sure what parts i am missing if any?
Dave.
When I got mine the fuse box was not screw in on the legs that come of the side this was because it had the relay to the head light change and this was bigger than og relay so if you try to fit it the relay got in the way fitted og relay and now it fits just right hope this helps ps took clocks out to see what I was doing in the wire spaghetti
Hi here a couple of pics of mine,it sits in a cradle and is screwed to the front panel although I've bent mine back a bit due to a leaky screen
Cheers mark
probably get one off someone breaking a bus.
You can see the cradle better in this pic as my fuse box is hanging out of it;
Soon as you have to put a new bracket on anyway i'm told the position of the fuse box on later bays was much improved as it doesn't get soaked if the screen leaks a little so may be worth moving it??
I'll be moving mine, not sure exactly where they have them and can't find a pic, i'll have a butchers at my mates when i see him next
