Got a couple of leaks on my gearbox that need fixing.
1st leak is from ware the selector shaft goes into the box.
In my parts catalogues it shows a bush that goes behind the seal.Can that be changed without taking the nosecone (think thats what its called) off. If so can it be changed in situ or do you have to take the box out.
2nd Leak is from my ns driveshaft hub flange. Basicly think i should be ok with that but tips and advice always welcomed :mrgreen: .
Is there any adjustment to be made at the diff as there is a small (ish) amount of latteral play in the flange which i believe is why the seal has failed.
Thanks in advance for any input.
Rich
Rich
