mr scoops
- Joined
- May 8, 2010
- Messages
- 1,144
- Reaction score
- 0
Since I've fitted the CSP shifter to SuperDry the actual shift is so much better than with the EMPI shifter it came with.
One thing I've noted that hasn't improved is that if I've been bimbling around town in it, it shifts nicely, but sit on the motorway for more than a few junctions and it doesn't like going in to second or first.
Is it worth changing the gearbox oil, there's every chance that the oil in there is years, if not decades old.
In which case, what oil should I replace it with?
I'm going to Halfrauds tomorrow to get a drain plug tool on the way home and plan to get the oil too.
I'm going to undo the fill bolt before the sump drain.
Am I right in thinking I have to get the front of the bus in the air too to make sure the Bus is level when I put the new oil in.
Is it okay to simply drain the old stuff and then fill it with new or do I need a flush?
Any other hints, tips or advice is most welcome!
