gene berg shifters.
carl_hendy827
Active member
Oct 7, 2009
36
Will be doing a gene berg shifter run at the end of Feb,
need confirmations by 15th feb.
name below with model needed.
Cost will be 245pound insured delivered to your door in uk with all taxes and duties paid.
GB 6746 Pre 1960 bus shifter. Chassis number up through 501706, ball diameter 15.7mm. Polished inset T handle as standard subject to availability. Please note that you should always check your ball diameter BEFORE ordering as we are seeing a rising number of cases where previous owners have replaced the stock shift rod with the 60-65 one. We are able to make a hybrid shifter for this, as neither the GB 6746 or 6748 will work correctly.
GB 6746R As GB 6746, however, for right hand drive. Black T as standard, subject to stock levels.
GB 6748 60-65 bus shifter. Fits chassis number 501707 through 216-028-111. Will not fit the older vehicles with a straight shift rod and smaller ball. Our ball is standard 21.50mm. Approx 7/8" from bottom of base to bottom of ball. Total length approx 25" floor to top of handle. Polished handle as standard. Handle color subject to change.
GB 6748R As GB 6748, however, for right hand drive. Approx 7/8" from bottom of base to bottom of ball.. Ball is 21mm. Handle color subject to change. Total length approx 25" floor to top of handle.
GB 6749 This shifter is for LHD pre '60 (pre 501707 VIN) that have had the '60-'65 shift rod with 21.5mm ball socket retro-fitted.
GB 6749R This shifter is for RHD pre '60 (pre 501707 VIN) that have had the '60-'65 shift rod with 21.5mm ball socket retro-fitted.
GB 6750 66-79 bus shifter. Fits chassis number 216-028-112 to the Vanagon. Approx 1-1/2" from bottom of base to bottom of ball. Polised inset T handle as standard. Length approx 25" from floor to top of handle.
GB 6750R 66-79 bus shifter. Fits chassis number 216-028-112 to the Vanagon. For right hand drive buses. We have bent this shifter the opposite way and installed our right hand drive handle. Approx 1-1/2" from base to bottom of ball. Total length approx 25" from floor to top of handle.
i can also get beetle and ghia ones.
carl.
I got one of these from Carl last year.
It's really good and well worth the money.
I would also be interested in a locking one for our 1970 lhd bay.
Can you get a price please.
locking shifters are available and will be priced around £430 all in delivered all duties and taxes paid.
PLEASE PM WITH YOUR ORDER AND I WILL ADD YOU TO THE LIST!!! STATE WHAT SHIFTER YOU REQUIRE.
MANY THANKS CARL.
Supertramp said:
Anyone else doing this?
Can't decide between a ball handle or the T one.
If it helps; I have a T-Handle one and I wouldn't trade it for anything (except maybe one with a locking base ;))
Cheers.
Not sure if this is happening, haven't heard anything and think the deadline has been and gone.
