Just stuck my hand behind the dash to be met with sparks and smoke and melting wires. Ran to the engine lid and took me a while to find my 13mm spanner for the battery. Anyway, got it off and removed the dash pod. Turns out the main wire which runs from the battery (via starter) to the front goes straight to the light switch and I had accidentally pulled it out by brushing a wire with my hand! It then grounded itself and melted the plastic sleeve.
Lesson learned, buy a quick release for the battery! I was panicking as I could not find a spanner!
Why does the large wire which runs from back to front not have a fuse? I see that it goes into the switch and then out to the fusebox. Bit odd, but correct according to the wiring diagram.
