Early Homer
Hi all,
So I've got the itch to build a tasty 1776 based on my semi-stock 1600dp.
Here is what I have currently;
-Stock aluminum cased bottom end
-Stock heads
-Pair of very clean Dellorto 36 DRLAs with CB linkage, filters etc
-Filter king fuel pressure regulator/filter
-123 electronic distributor
-VW Speed Shop 1.5" hideaway muffler system for stock heat exchangers
I'm looking for the ideal components to complement a 1776 running 36 Dells and stock heat exchangers. This will be my first engine build so I need some help primarily with a definitive spec so I can start amassing parts.
So I've researched on the net about 90.5 pistons and cylinders, machining, boring, balancing, porting and polishing, port matching, full flow etc but I'd like some real world advice on which components I need to build the best engine I can around what I already have.
Where I start glazing over is on the subject of crank sizes and cams. What is ideal for a 1776 bus as I guess this varies from a bug spec motor. How wild can I go and what are pros and cons?
-Stock heads
