Hi all, I'm hoping someone has fitted one of these...
I'm trying to fit a Heritage rear seat belt bracket and I am confused - it doesn't take much!
Our 71 Westy currently has a static 3point belt on the near side, bolted into the factory anchor below the window (behind the seat), and then bolted in under the seat.
It appears that the only bolt hole that lines up to the bracket is the factory anchor, which would then allow the bracket to rotate around it - there's no lower fastening. There is an elongated hole (see pic) that looks like it should line up to another hole or bolt, but there is nothing to fix it to.
Can anyone advise me - am I missing something, or should it just fit with the one bolt?
[/URL]
