Good evening folks,
I'm trying to identify what the brackets look like that hold the rear curved plywood piece found on 1968 Westys to the van. I will follow up with some photos, but in the meantime, the parts I have are the curved wood, and the middle cargo net support bracket. I can see that this bracket screws into the centre of the curved wood piece through one of the holes, and then there's another hole above this that I believe just a single screw goes through. I presume that one or both of these attach to a bracket of some kind behind the curved wood. Then there's holes on either side of the curved wood where I can clearly see the outline of where a bracket has been.
From what I can see of the original holes in the metalwork of the van, there are single holes on either side of the boot opening up on the strengthener pieces, and then two holes in the centre. These match up with the locations of the bracket holes in the wood, so that's a plus!
I've been sent the below photo, but the seller is not sure if the brackets are correct, and I'm not sure that the bolt holes line up with what I'm seeing with what I have.
If anyone could shed some light, that'd be appreciated as much Google searching has yielded nothing! Is it just three brackets that screw to the roof, or is there more to it?
![](https://proxy.imagearchive.com/f8d/f8d77146c02ad5637cbe5639bd9d5519.jpg)
