Bazzaworld
- Joined
- Dec 5, 2013
- Messages
- 335
- Reaction score
- 0
I'm hoping someone can help, I'll try to explain as simply as I can,
We took or bus out this morning and I noticed the fuel gauge was bouncing around then settling for a while before bouncing around again. Then this afternoon I took my young daughter for a short journey when all of a sudden smoke began bellowing out from the dash,I immediately turned off the ignition , jumped out and took the earth lead off the battery, I took off the steering wheel and dropped the dash foward and on closer inspection one of the wires from the fuel gauge and a wire from the ignition had completely burnt out, but because I was quick nothing else, it seems that one of the fuel gauge terminals is lose causing the wire to touch the dash(should be isolated) I replaced the wire from the ignition but left the fuel gauge unconnected for now , now I have nothing on the ignition side, no dash warning lights no wipers etc so obviously it won't turn over or start ,but everything else is working lights, radio, hazards etc I've checked all fuses and they seem ok
We ended up on the back of a lovely yellow AA truck much to the amusement of my nosey neighbours. Anyone have a clue??? :|
