Mickey Sam
I have just stripped the roof of my bus back to bare metal and am going to re-spray it in celulose.
I have found slight rust spots approx 2" diameter which look like they have been sealed or treated in the past.
I need to know if I should grind the rusted areas, then treat the whole roof with Kurust treatment, let it dry ,
and then sand before adding etch primer.
I have used zinc primer over rust treatment on the inside of the van but have never sprayed a final finish over
rust treatment before so could anyone confirm if I have the right order of application...
Shoot me down in flames if need be but please set me off on the right foot as I would like to get this right first time .
After nearly 4 years into the resto I would hate to ruin it by cocking up the paint job.
So, should I ........
Bare Metal
Rust Treat, then sand when dry ???
Filler
Fine filler
2 light coats etch, no sanding,
2-3 coats high build primer, only sand final coat ???
Apply several coats of cellulose colour, wet sanding in between each coat ???
Lacquer ( if final finish is not acceptable i.e polishing does not give the required effect)
Any comments would be appreciated and I am sure it would help others in my situation to see what you guys recommend, thanks,
Bare Metal
Filler
Fine filler
