So here are a few pics of the work I have started on my bus ..
At this point I would like to point out that this is my first real attempt at this sort of thing .. so any constructive critisism will be taken well!
If im doing it wrong tell me!
My theory is not to have a show bus but one that is mine, useable and safe ..
Started with the sliding door bottom .. cos it lost a handful of rust each time i slammed it ..
usual story .. bottom 6 inch inside and out ..
The inside damage was confined to the flat section so i made one up myself ..
obviously before i removed the outer so i knew where it went ..
Its not exactly how it was originally but functional ..
Then an outer skin and test fit and adjust ..
Complete welds .. seam sealer .. skim of filler and shape and prime ..
... and some rattle can paint to stop the primer soaking in water till i get round to the respray!
Started on the front step area next cos its shot underneath ..
DO I GET A PRIZE FOR FINDING PREVIOUS REPAIRS WITH NEWSPAPER !!
The first bit of paper i pulled out read "Do it Yourself!" how apt! .. the paper was dated June 1991 ... anyone owning up!
Previous repairs have been done over the previous rust ...
Is it just me or do you need a sit down and cry after you have poked away at your precious bus and the brown stuff gets larger and larger ..
I particularly like the way the previous ape has smacked the lower b post in with an hammer about 2 or 3 mm to allow a new one to be welded on top!
More stuff to follow ..
Hilly
