Ok .. I aint posted for a bit .. but i tried last week and was overcome by alcohol ..
Done a bit since last posted , but not as much as I would like .. Looks like the beetle and tent for the rest of the shows this year ..
Anyway ..
Front on, skimmed and tidied .. Removed drivers side dog leg, wheel tub (or 90% of ..) and repairs made to rear closing panel ..
frost clips doing a fine job again ..
I wanted to keep the bulge but the cut i had was also rotten there, but if you cut away under the seat area theres another just waiting to be flipped ..!
Ok .. a little patchy but the desired effect .. Also lots of B pillar repairs and new outer .. ( I'll not bore you with those pics though ..
Now for the front arch ... Yippee another quality repro fit ..
Wouldn't sit where i wanted with the old jacking technique!
Have be a bit more persuasive and chop the bastard in half a remove some ..
A brace bar to keep it in place too as theres no tub in ..
thats better .. not perfect .. but better!
New tub goes in .. ( it was solid before but patched, and I wanted it in one piece..)
Cut the new one in on the seam line and joddled it as they are slightly different from the originals ..
New floor panel removing all patches ..
Tacked in ..
and tidied up ..
And a seam where there should be one is always important!
New tub on other side ( again solid but removed patches .. )
and floor done and so forth ..
I'll not put them pics up cos they are just the same in reverse ..
The arch was new but i just tickled a piece out near the bumper end cos it was sticking out too much before ..
Thats the front end nearly done .. Beam is built up with Red9 and just itching to go back on ..
with all new ball joints/ beam/ brakepipes / flexi's etc ..
Let us know what you think guys ..
Hilly
