It needs to be routed above the level of the top of the carburettor, to prevent fuel from going into the vacuum mechanism.
Your local motor factor will sell suitable gauge rubber pipe - take the dizzy in the store with you.
For the metal section of the pipe, to route it above the top of the carb, you can use metal brake or fuel line. I have found normal brake line is the correct OD to suit
