vwvanman0
I fitted a powerspark module into my 009 the other day,timing was then out so i retimed it to 28 degrees @3000 rpm.
I use my van for my trips to work only around 8 miles.i stopped near home the other day and when i tried to restart it turned over very slowly,got home and tried it later and it was fine.
Today i went 20 miles and parked,when i tried to restart it was like the battery had gone flat,after a few goes it just fired,got home around 4 hours ago and ive just been and tried it and its back to normal.
Ive searched the threads on here re hot start and mostly its about fitting a relay.ive had the van 12 yrs and this has never been an issue.
My main worry is that the engine is getting too hot,do i need to alter my mixture to go with the new ignition? i have twin 36 dellortos fitted.
thanks,Steve.
thanks,Steve.
