I have read post after post (on other sites as well :shock: ) of how to fit Porsche Alloys to a Bay Window, and was after a definative answer maybe a sticky :?:
I know there are a lot of variables ride height (narrower tyres on the rear to stop rubbing) and how it was done (adjusters and splines etc), ETs (et 23, et 36 or et53 maybe more), narrowed beams etc
My Bus will be a 71 DeLuxe (on its way) replacing my fire destroyed 72
I have bought some horseshoes for the rear off lowerlight (shameless plug) and will get drop spindles preferably from Transporthaus (seem the best option, other drop spindles are available)
I want to avoid using adapters (but may have them on the front if a necessity) and know these are available
So to the options:
1)Porsche pattern disk kit all round - around £1600
2)Creative Engineering Porsche pattern rear drums with porsche 944 hubs, 911 disks and boxter/aftermarket calipers inc fitting kit - around £600 (depending on fleabay availabilty of parts)
3) Get both standard front hubs and rear drums re-drilled to allow fitment of porsche pattern. Ive seen a step by step thing on front hubs. But do i need wide 5 on the rear in order to be able to redrill into the hub (makes sense in my head or is it late bay drums)
4) A mixture of any of the above
So am now totally lost.
I have bought a set of Cookie Cutters off Andy on here Front 6" (et36) and Rear 7" (et23). And know these are ok to fit with any of the above options as i am not widening the track
Im also looking at getting some teledials but they tend to be sets of 7"'s with et23, backs will be fine but are they to big for fronts, or do i need 7" et52 teledials or 6" with either et23 or et52, can you see where this is heading :roll:
Any help, advice, pics of peoples current set ups etc would be welcome. there are enough bus's out then on Porsche wheels, i just want to know the cheapest safest way, as i am not going to compromise safety.
So to the options:
