Hi folks.
Indicator is blinking too fast, all bulbs are working and hazards are running at normal speed.
Its a US import with the single bulb rear indicator/brake light. I've rewired to UK Spec: installed new light housings and lenses at the back with separate indicator and brake light bulbs. Then disconnected and ran the yellow wire from behind the hazard switch to the brake lights.
It's all working properly apart from its blinking twice as fast on indicating. Is there a resistor i need to add or adjust?
Cheers guys.
Pete
Cheers guys.
Pete
