Resto-raider
Hey guys,
My bus is almost ready for MOT but I'm still fussing around with the electrics. Most of the electrics work now, but I can't get the indicators to work. The PO cut the entire loom that goes towards the indicator handle on the steering wheel. In this loom there are 8 cables, but my indicator handle only has 5 connections.
The colours correspond to the colours in this wiring diagram http://www.thesamba.com/vw/archives/info/wiring/baybus_6869a.jpg
The 3 cables that I have yet to connect are the red/black, the yellow/black and the purple/black cables.
I don't know what the purple/black cable does. One end comes from the emergency flasher switch and the other end comes from a wiring loom that goes behind the front panel.
The other two cables are to indicate on the rear left and right and are currently not conneted to anything, but why don't they go to the indicator relais? In the diagram they go directly from the indicator handle to the rear.
What to do with these 3 cables?
Any help would be greatly appreciated.
Cheers,
Rick
Cheers,
Rick
