phil_n
I've had an ongoing problem with my indicators for a while now. At first I thought it was an issue with the hazard switch, but I replaced this and it still persists.
Essentially they stopped flashing, but worked on constant. This has now progressed to not working at all unless you first turn the hazards on, switch the indicator on and then turn the hazards off! Even then it just leaves you with a constant light on the side selected.
The bus is a '70 Westy USA import which has had the indicators transferred into the reverse lights before I bought it.
Any help would be greatly apreciated!
Phil
Phil
