Lowlighter
Active member
- Joined
- Feb 26, 2009
- Messages
- 41
- Reaction score
- 0
It's probably your bump stops!
Best way to check is to load up the front of your bus with bags of concrete/friends/water until it won't go lower - then check if your bump stops are fouling your trailing arms - if so, you may have to get your hacksaw out (don't worry though as lowered bump stops are available from Red9!)!
Good luck
[/quote]
I have already removed both top and bottom bump stops completly and when it bottoms out it sounds like metal on metal but I guess that could be the shocks. What did you do with yours?
Good luck
