BRAD
When turning the wheel slightly left or right I get a knocking sound, any ideas before I go rooting around underneath?
I have original worm drive steering box.
Happystamps said:Take a driver's seat, keep the door open and move the wheel back and forth over the straight ahead position- if you can more the steering wheel before the road wheels move, you've got play, usually in a ball joint somewhere. they're pretty easy to replace, but you'll likely need to get it tracked afterwards. It's possible that play also means your box needs adjusting. You'll be able to see which bit has play in it by getting underneath while someone turns the wheel and looking at the moving bits. You'll find a bit that's moving, connected to a bit that looks like it should be moving, but isn't (because of the slop between the two parts). That'll be your duff ball joint, probably.
If your steering wheel doesn't move before your road wheels, something weird is happening- perhaps an imp or gremlin trying to get into your van as you drive along. If you suspect this is happening by no means look under the bus, just drive it out to a field, burn it, and claim it was stolen for insurance money.
BRAD said:Cheers HS, but I have literally replaced the three rods, ball joints, damper, shocks about 5 months ago, I'll get under it once I man up or it gets warmer!.
