meowdmucker
After getting my engine back from a rebuild I have an oil leak which appears to be coming out of the two upper bolts which attatch the oil cooler to its mounting.( twin port) The cooler is a new one. The main cooler mounting to case is dry but oil is running down the back of the cooler and dripping onto the cylinders through the gap in the cylinder cover tinware. It could be that they were never tightened enough by the builder as I could tighten them a couple of turns but not sure if they should have sealant behind them and if this extra couple of turns will seal the leak. ie should they be as tight as possible? It looks like there are small plastic washers with a metal spring washer above this. I don't want to fit the engine again and slill have the leak so would be grateful if anybody knows the correct way to secure the cooler to its mounting? Ps the engine builder was less than helpful with this matter- enough said!
