Hi Guys!
Finally got the Van Motd last week - now just the odd fettle now again now shes on the road to try and keep her there!
Been tuning the engine - done a lot of research on Interweb ref static/strobe timing. Now back in the day when I had beetles I would always set timing by A) Turning ignition on. B) Turning engine over by hand (till No1 gonna fire) and then listen out for a click. Set the click to about 7 or 8 degres BTDC by tweeking the dizzy and voila. Now with my freshly built 1600 SP I have done the same. This however has a 009 dizzy (otherwise stock apart from an awesome :!: monza 4 tip). Now my question is - in order to get the engine to idle I have had to screw the idle control screw on the lever arm RIGHT in with only a few threads on myside of the arm? If I advance the timing it runs faster at idlel but pinks its tits off in 4th gear on a hill. So basically have set timing at correct setting to avoid pinking (bad for engine!) but now have a very low idle - in fact it can cut out when slowing for junctions. A quick dab of the pedal usually saves it and then it will idle. Am i doing anthing wrong? The mixture screw in the side is set at 2.5 times out from in (when I overhauled the carb).
The throttle cable only seems to come thru the fan housing and into the screw barrel just enuff to be honest too (sure on the bug there was about 10mm of cable sticking out of the barrel when tightend!)Not sure if this is related but thought would mention it!
Any pointers would be greatly apreciated! ALl the pics i have seen of carbs the idle screw seem to be about half way in! I have a solex 30 pict 2.
